  • 2 Vote(s) - 3.5 Average
Rusted Sump
Even though I knew they were prone to rusting, and that i had over the past 5 years taken preventative measure to prevent it happening by cleaning and painting and applying Kerrust etc, my 2003 1.9 diesel engine steel sump has rusted through at the front just below the oil filter and oil is dripping out when the engine is running, can anyone here tell me where I can purchase a decent quality replacement please. I see they are on sale on Ebay, but are they a decent quality? thanks.
There is a thread on this & I think you have the option of an ally one.:thumbsup:
Thanks for that, Ive purchased a steel like for like sump from Eurocarparts for £72, plus gasket for £8. Cheers
Sorry to say this but that seems expensive - it is around 5 years ago but I paid less than that from Citroen and it didn't need a gasket, it uses sealant. There certainly wasn't a gasket on ours when I replaced it.
For prevention I always wipe it with the old oil when I do an oil change - as we do at least 15K miles per year that means it gets a coating reasonably often.
I paint mine with Waxoyl when it's cooling down,3 times a year.I do the exh tailpipe as well.:thumbsup:Confusedalut:
Changed the sump between the showers during the weekend, as mentioned above there was no gasket fitted, just clear sealant but used the gasket i got with a tube of Hylomar I got from work, sealed it up nicely, no leaks, except the sump plug has a drop of oil on it every time i look under, the new sump didnt come with a new plug n copper washer, had to fit the old one....so Im gonna take the plug out and heat the washer up in the sitting room fire to soften it and then refit. Job took an hour.
Don't be so tight, buy a new washer
Here we go again, I've reused the old washer for 7 years without a leak. Over 1000000 miles and at least a dozen oil changes.
If it ain't broke don't fix it :whistle:
I never changed the washer on our old Berlingo but it didn't leak. I would change it 7f 7t was leaking.
I may have to change thse sump on our 2007 Romahome because it is very rusty at the front even though I treat it every 6 months when I change the oil.
Peter
(13-02-2014, 09:18 AM)steve valentine Wrote:  Here we go again, I've reused the old washer for 7 years without a leak. Over 1000000 miles and at least a dozen oil changes.
The Dowty washers can be re-used but I always change the copper ones & definitely the crush type. I am not known to be liberal with the folding stuff but for the price of a washer,sod the expense.Confusedalut:
Forum activity
Today 01:15 PM
Emissions fault.
11-05-2025 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
09-05-2025 09:34 PM
Insurance Shocker !!!
Last Post: Keefus.
09-05-2025 01:45 PM
Part of Dipstick Stuck
Last Post: Nice4dad
09-05-2025 01:25 PM
BSI central locking again
Last Post: stuffe
09-05-2025 09:24 AM
» Replies: 23
steering column bearings
07-05-2025 07:53 PM
