Threads: 5
Thanks Received: 2 in 2 posts
31-01-2014, 10:10 PM
(This post was last modified: 31-01-2014, 10:12 PM by kahan.)
New to the forum and car as well.
Just purchased a 2007 1.4 Berlingo van (60K on clock) my first frog car it has some unique design features impressed so far.
I have been going over it with a fine tooth comb and want to change the spark plugs, is there a guide available to show me how to do it.
It is hard to get stuff over here.
Kahan
If you ain't Cav you ain't
The following 1 user says Thank You to kahan for this post:1 user says Thank You to kahan for this post
• Ol'Jeffers
Threads: 50
Thanks Given: 743
31-01-2014, 10:17 PM
(This post was last modified: 31-01-2014, 10:18 PM by Ol'Jeffers.)
Welcome Kahan!!
We have couple of members who are from Oz and one of them, Addo
is an Berlingo expert beyond belief! He'll be along shortly to give you the
answer and probably tell you where to source stuff in Oz.
Which bit are you in....the hot and very sweaty north or the not quite as hot and sweaty south?
Threads: 44
Thanks Received: 67 in 56 posts
Thanks Given: 9
10
It's pretty easy you just need some Torx screwdriver and a deep socket. Remove the top cover, unscrew the coil pack which is a whole sealed unit and lifts off from all 4 cylinders, then you will see the spark plugs. Just take it easy when screwing the spark plugs back in as you don't want to feel any resistance as that is a clue that you are cross threading. You don't even have to disconnect the coil pack, just lift it and rest it to the side.
Threads: 7
Thanks Given: 25
Thanks for the hints here guys!! My plugs wouldn't budge and I was scared to force them. What we found was the 16mm socket was actually jamming on the tubular casing so ground the socket down so it didn't stick any longer!! It also helps to have the motor hot as the plugs come out a lot easier.
Threads: 5
Thanks Given: 4
21
Cheap box plug spanners, that come with things like strimmers, have a thin wall and don't snag up.
