Threads: 6
Thanks Received: 3 in 2 posts
Hi guys I have just picked up a mk1 multispace and it pulls well but the steering feels off?? I thought it had a snapped spring as it made a sort of 'piano twang' on a hard right hand turn but when I checked today the springs were fine.
I then thought strut top mount maybe?? It drives straight no wobbles etc but when I'm turning the wheel on a round about it just doesn't feel right if that makes sense? Almost like it pulling against me as if the tracking were out??
Any ideas guys I'm sure there could be lots of variables etc...
Any advice is a help
Cheers
Koojo
Threads: 6
Are they an easy(ish) job to do? Did you buy OE parts or does it not matter??
Cheers
Threads: 3
Thanks Received: 8 in 6 posts
mines is a taxi so its gets a steady diet of Peugeot parts as they do seem to last longer. not a major job but can be a bit of a faff if you don't know what your doing
Threads: 6
01-02-2014, 08:21 PM
(This post was last modified: 01-02-2014, 08:25 PM by Koojo.)
Yeah I guess being a taxi your going to have a few consumables on the day to day running.
Do you buy the parts from Peugeot main dealers or say europarts or whoever???
Cheer
KYB Front Left or Right Suspension mounting kit/Top strut mount SM1906-KYB
£22.72
Are these any good from eBay or should I stay away from the 'bay'???
Threads: 3
No everything comes direct from peugeot
Fortunate enough to have a trade account which saves anywhere from 10-40% depending on what I'm getting
Threads: 43
Thanks Received: 411 in 368 posts
Thanks Given: 137
32
Koojo said,
"" Hi guys I have just picked up a mk1 multispace and it pulls well but the steering feels off?? I thought it had a snapped spring as it made a sort of 'piano twang' on a hard right hand turn but when I checked today the springs were fine.
I then thought strut top mount maybe?? It drives straight no wobbles etc but when I'm turning the wheel on a round about it just doesn't feel right if that makes sense? Almost like it pulling against me as if the tracking were out??""
Symptoms of a broken top spring coil . The piano twang can be the broken end moving about
Threads: 17
Thanks Received: 40 in 32 posts
Thanks Given: 6
+1. There was a recall to fit metal protectors at the top of the strut to stop the broken spring damaging the tyre.
Griff
Landmark
Ex 1.4 Berlingo Multispace
Threads: 6
Hi guys
I was planning on getting the top mounts fitted next week but if peeps think its the top of the spring ill have to get the garage to check first then order the parts so ill have to rely on the garage getting either OE from citr/Peugeot or some motor factor copy part?? What would you guys advise??
I bought the van cheapish for a run about don't want to be spending great amounts in repairs for over priced parts, labour, etc...
Tbh I think the top mounts are goosed as the wheels feel great when straight but a bit of lock turning a corner I'm fighting almost against the wheel?? Almost like the tracking is out? But at motorway speeds it has no wobbles.....
Advice much appreciated guys:-)
