  • 5 Vote(s) - 4.2 Average
2013 Berlingo Enterprise - Teletrac
Guys
Can anyone help me out here.
I've bought a 2013 Berlingo from Donnelly's in Dungannon, Northern Ireland and it came fitted with a Teletrac unit. However, I am using the van down south and I cannot activate the unit, just doesn't connect.
Any ideas?
Secondly, the power cable looks like a standard mini USB but does fit into my Garmin, seem to be slightly different. Has anyone mangered to use the cable with a Garmin or TomTom. It would say having to plug the Garmin into the lighter socket.
Ok, after doing a bit of investigation it seems that the Mini USB cable which powers the SmartNav is actually a 10pin Mini USB connector whereas most other SatNav systems use a 5pin Mini USB connector.
Don't seem to be able to get a convertor for them so I order some 10pin Mini USB female sockets and going to make my own SmartNav-2-Garmin cable.
It's only 2 wires that need soldering, pin 1 (+5v) and pint 5 (GRND)
Should be a simply enough job, then I can use my Garmin or TomTom from the SmartNav cable.
Rear seat belt breakage
Last Post: Mad one
Yesterday 06:09 PM
Yesterday 05:49 AM
11-09-2026 11:36 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
