Threads: 52
Thanks Given: 87
5
Maybe I'm missing something but if you're talking simply about replacing the H4 bulb for the headlights (low and high beam) it's a 10 minute job. Done it three times so far.
Threads: 39
Thanks Given: 1
4
MK 2 no problem either, you just have to loosen the headlamp and ease it forwards a bit to get your hand in or find someone with a small hand.
Peter
Threads: 52
Thanks Given: 87
5
Yes, from the engine bay. Slide off the largest round rubber cap behind the light and that exposes the bulb and connector. Pull off the electrical connector, move the spring loaded clip holding the bulb in place out of the way and then remove bulb. Replace bulb, re-engage spring clip (clips at the top) and reconnect electrics and replace rubber dust cover. If you sort of stand on your head in the engine compartment and shine a torch on the assembly it becomes apparent.
I was doing this very task at the weekend, and the part that the spring clip goes into came away, and dropped down under the headlamp reflector. Various attempts to retrieve it failed - magnet, bluetack on a stick, bent coathanger.
It looks like I have two options - 1. remove the whole headlamp assembly (which I gather involves removing most of the front of the car) turn it upside down and shake it or
2. try and obtain a replacement clip.
Are these readily available, or is it one of these things where you have to buy the whole headlamp assembly to get a 10p clip?
Threads: 32
Thanks Given: 18
(06-02-2014, 07:58 AM)Romahomepete Wrote: MK 2 no problem either, you just have to loosen the headlamp and ease it forwards a bit to get your hand in or find someone with a small hand.
Peter
I managed it on my MK2 without loosening the headlamp and I've got shovels for hands.
I did remove most of the skin on my knuckles though
illyme:
Threads: 16
Thanks Given: 46
5
I used an inspection mirror to see how to undo clip & it does help. It is difficult to work out how to undo clip just by feel, you need to see it.
Threads: 0
Thanks Given: 2
I managed to changed the O/S (driver's side) lamp relatively easily a few weeks ago and then the N/S one went. Different kettle of fish regards access to the rear of the headlight. Could get the circular cover off, but that's as far as it goes and I don't have big hands, but I just knew that with the severely reduced access due to location of electronics boxes immediately behind headlamp that I would struggle to deal with the spring clips holding the lamp in place. Figured I need to improve the access but I'd like to know which approach to take - remote front grill etc or try to shift electronics boxes? What is the easiest/best way to achieve this?
