Threads: 17
Thanks Received: 4 in 3 posts
Thanks Given: 26
Anyone got any pics or a good description where the bulb or whatever it is is on my 99 1.9d PLEASE!!!:brickwall::brickwall::brickwall::brickwall::brickwall:
Threads: 32
Thanks Given: 13
Do a search. There are definitely some pics of it on here in old threads.
I don't have that engine, but have seen it posted before.
The following 1 user says Thank You to tucker for this post:1 user says Thank You to tucker for this post
• 7tradey1
Threads: 51
Thanks Given: 23
If it doesn't have the bulb maybe it has the pushbutton version? In which case it will be on the side of the fuel filter front passenger side of the engine.
Malc
Stupid computer!
Threads: 39
Thanks Given: 1
4
Depends which engine.
XUD should have a small rugby ball shaped ball with fuel lines attached somewhere near the offside wing.
DW8 has a button on top of the fuel filter which is at the battery end of the engine.
You will have got air in now but your original problem sounds like heater plugs not working ie athe almost starts.
Peter
