  • 1 Vote(s) - 4 Average
air bag light
Sad
i have an 03 berlingo multispace, the airbag light comes on when my drivers seat is moved, usually i wiggle the wires under seat & it goes off. it wont this time & is up for mot! every1 is on about the orange plug under seat but i cant find it. just a few leads! help please! Rolleyes
Not sure which wire it is but if you want to get the light to behave as it needs to for the MOT and are prepared to accept the airbag not being operational you can unplug one wire and it is just the right size to accept a bulb like this - http://www.halfords.com/webapp/wcs/store...yId_165538
The bulb creates the resistance required for the circuitry to think everything is working properly and the light behaves as it should. Some insulation tape over the bulb stops it lighting up the under seat area!
[-] The following 1 user says Thank You to andyps for this post:
  • joanne
The blooming airbag wiring under the seat is awful, I find if the wiring is disturbed in any way then the light comes on. It popped on on Sunday evening because the box of spare bulbs I keep behind the drivers seat had crept forward and knocked the wiring. Mines also due for it's MOT shortly, I'm just hoping the light stays off.
[-] The following 1 user says Thank You to stuartinlancashire for this post:
  • joanne
I got so fed up that I ended up removing the connections and making the connections with screw connecting blocks, a bit fiddly to do under the seat but no trouble afterwards
Peter
[-] The following 1 user says Thank You to Romahomepete for this post:
  • joanne
Mine used to come on everytime the seat was moved which was a big problem as my wife had short stumpy legs and I am 6ft 2in.
I manage to resolve the problem with a simple divorce.... No air bag light issues now Smile
[-] The following 1 user says Thank You to tucker for this post:
  • joanne
(11-02-2014, 12:31 PM)tucker Wrote:  Mine used to come on everytime the seat was moved which was a big problem as my wife had short stumpy legs and I am 6ft 2in.
lol! very gud! we hav the same problem with short legs & longer 1s! normally moving the wires took it out but not this time! had d get it on computer d get it out last nite! :lol:
(11-02-2014, 11:58 AM)Romahomepete Wrote:  I got so fed up that I ended up removing the connections and making the connections with screw connecting blocks, a bit fiddly to do under the seat but no trouble afterwards
Peter
we changed wires & all but no joy, light was still on. got it on a computer last nite, turned out it was my indicator arm causing the problem, instead of my indicator knocking off wen i go round a corner it indicated the other way! light is now out! thanks for reply!
(11-02-2014, 11:02 AM)stuartinlancashire Wrote:  The blooming airbag wiring under the seat is awful, I find if the wiring is disturbed in any way then the light comes on. It popped on on Sunday evening because the box of spare bulbs I keep behind the drivers seat had crept forward and knocked the wiring. Mines also due for it's MOT shortly, I'm just hoping the light stays off.
mite always came on but a wee jiggle at d wires took it out up until now. we changed wires & all but no joy, light was still on. got it on a computer last nite, turned out it was my indicator arm causing the problem, instead of my indicator knocking off wen i go round a corner it indicated the other way! light is now out! thanks for reply! :lol:
I simply disconnected those and sprayed in a little contact cleaner, let dry a few minutes, replugged, and it's all good. No probs with the light since.
[Image: 177657.png]   2004 1.9D DW8 WJY with black spray paint on wheels instead of flimsy plastic wheel covers.
[-] The following 1 user says Thank You to teddyc1 for this post:
  • joanne
tried that also! had d end up getting it put on computer. turned out it was my indicator arm causing the problem! when i turn a corner instead of it goin off it indicates in the other direction!
Last Post: BigVtwin996
Today 08:25 PM
Ahh bless them...
Yesterday 04:54 PM
Yesterday 04:45 PM
Last Post: stu76
Yesterday 05:41 AM
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
