  • 1 Vote(s) - 4 Average
1.9 valve clearances
Has anyone on here adjusted or checked their own 1.9 valve clearances, do you have to remove the camshaft to adjust the shim thickness or can the shims be flicked out and changed with shaft in situ? Cheers
Camshaft out I'm afraid.I would advise changing the cambelt as a kit & waterpump. It was one of Fiats good ideas to design the cam followers to allow in situ adjustment.:thumbsup:Confusedalut:Check the clearances before removing shaft & write them down.For tight gaps-subtract from shim thickness.If some are within tolerance,you can safely have a few thou extra slack without making it rattle too much.
  • addo
Newbie
Last Post: DannyWxM
Today 07:39 PM
Thermostat Overheating, Radiator Cool
Today 07:34 PM
Oil consumption at 200K miles
Yesterday 12:47 PM
21-05-2025 06:54 AM
20-05-2025 09:42 AM
» Replies: 54
Last Post: rnamman
19-05-2025 02:03 PM
Last Post: allanr
18-05-2025 05:57 PM
Forum activity
17-05-2025 06:32 AM
Emissions fault.
11-05-2025 06:29 AM
10-05-2025 05:31 PM
