  • 1 Vote(s) - 3 Average
[Steering & Suspension] Front Strut brace anyone use?
Hi All!
My Berlingo have some cracks in shock Absorber tower, so I'll need to use weld to fix it.
Take a look below:
[Image: cgzn.jpg]
Anyone has expected some problem like that? What kind of weld to use?
After the welding done, I think to made a Front Strut Brace, to give more hardness to car and prevent new problems...
Maybe another car strut brace fit? This one is of Saxo.
[Image: $T2eC16Z,!)8E9s4l8BDPBQMMZFOiIw~~60_12.JPG]
Regards!
Helton
You must have worse roads than us:whistle: For what it's worth,I would make up a plate to cover the whole tower,seam weld the outer & inner joins.If your roads are that bad,a brace might be a good idea.Confusedalut::thumbsup: Good luck.
  • helton
(11-02-2014, 08:17 PM)ron Wrote:  You must have worse roads than us:whistle: For what it's worth,I would make up a plate to cover the whole tower,seam weld the outer & inner joins.If your roads are that bad,a brace might be a good idea.Confusedalut::thumbsup: Good luck.
The brazillian roads are pretty bad...
And the last owner did not periodic maintenance :S
I will start the restoration and in soon I will post some pics...
But if somebody use the front bars please comment here!!!
Eolys replacement tank
Last Post: Harrythephot
Today 12:02 PM
Today 10:27 AM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
