Threads: 26
Thanks Received: 6 in 5 posts
Thanks Given: 26
Hey guys can someone tell me where the jack is on a 11 reg mark 3 I have looked everywhere
thanks
Threads: 32
Thanks Given: 13
Might be the same, but on MK2 it's on the right hand side of the boot. The panel comes off and the jack is behind it...
The following 1 user says Thank You to tucker for this post:1 user says Thank You to tucker for this post
• steelviper
Threads: 32
Thanks Given: 13
The right hand side as you look at the car from the back. There should be some plastic retaining clips that you turn and then you can remove the panel. You have to half turn them first if it's the same set up.
• steelviper
Threads: 23
Thanks Given: 46
5
11-02-2014, 03:13 PM
(This post was last modified: 11-02-2014, 03:14 PM by Trevor.)
(11-02-2014, 02:40 PM)steelviper Wrote: Hey guys can someone tell me where the jack is on a 11 reg mark 3 I have looked everywhere
thanks
Look under either the passengers or drivers seat, there is a bit of carpet that lifts out and it will be under there. Mine is under the passengers seat.
You need to look from behind the seat.
The following 1 user says Thank You to Trevor for this post:1 user says Thank You to Trevor for this post
• steelviper
Threads: 35
Thanks Received: 119 in 88 posts
Thanks Given: 3
4
11-02-2014, 05:13 PM
(This post was last modified: 11-02-2014, 05:13 PM by ntm1275.)
As Trevor says, but mine is under the drivers seat along with all the other tools
The following 1 user says Thank You to ntm1275 for this post:1 user says Thank You to ntm1275 for this post
• steelviper
Threads: 15
Thanks Given: 46
5
Yes, thats where it should be with a clip in cover. Make sure you get whole kit, scissor jack & plastic roll with wheel brace & long right angled torx driver for removing fog light if you have to change it.
