Im looking for a diagram of the fuse box to locate the heater plugs fuse I think it is A1 but am unsure. If anyone can help I would appreciate it
Threads: 32
Thanks Given: 18
Year? Engine?
berlingo van 2002 desiel wont start turns over but wont fire up noticed heater plug light on dash is not lit anybody had same trouble and how did u fix it cheers
Threads: 23
Thanks Received: 501 in 458 posts
Thanks Given: 50
29
Hello james welcome to the forum how many miles as it done if around 100'000 the valve's clearance close down so the valve's stay open so you get low compression and will not start at first but when warm they will so first check the valve's and compression if of ok test glow plugs
Threads: 0
I have this problem - is it the relay?
Threads: 40
Thanks Given: 82
6
(24-11-2019, 05:17 PM)Leslie Wrote: I have this problem - is it the relay?
Is it starting or just the light not coming on?
