18-02-2014, 12:35 PM
Having run the car on bio diesel for 18months the fuel pump developed a leak.
It leaked all over the cam and aux belt and probably the alternator as well.
The pump's now been replaced with a used item and it runs really well.
Cam belt and aux belt are also replaced.
Now however there is no charge. The battery light is lit up on the dash (some of the time) and the battery is only 11.5volts with good revs.
Any suggestions?
(I'm thinking about just spraying the alternator full of contact cleaner and revving it up for a while to see if this cleans it out.)
I guess it is possible though that the insulation around the copper coils was dissolved by the leaked fuel?! In which case it'll need replacement.
Thanks.
Any suggestions?
Thanks.
