  • 7 Vote(s) - 2.86 Average
K&N air leaner for 1.4 ltr 2007 berlingo
How do you fit one and does it make a difference?
KAHAN.
If you ain't Cav you ain't
If it's just the filter it will fit strait in as the other filter you take out if they make one or are you on about an induction kit fitting instruction will be on the box
Mate,
I have seen one fitted directly to the air intake without the air box fitted,
How does this affect the performance and running of the car?
Kahan
You mite get 1 or 2 hp out of it depend's where it's fitted if you got cold air feed. If it's too close to the engine you will get heat soak warm air going into the intake
Today 12:17 PM
Last Post: wbchevron
Today 09:32 AM
Yesterday 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
