  • 3 Vote(s) - 1.67 Average
Max Payload
I have a window cleaning business, it's water fed pole so I carry lots of purified water, does anyone know the maximum weight you can carry in a 03 multispace 1.6 petrol?
Not sure on the numbers, but when I put even a couple of weighty passengers in the rear the arches are soon filled with wheel. You'd be better off with an 800 van
I looked it up once when I was due to carry a load of paving home, but can't recall what it was.
It was somewhere in the region of 600kg but including the driver / passengers... Not sure I'd go that heavy though in an older vehicle!
Personally I wouldn't chance a load of any more than 500kg in my 600X van even though it's supposed to have a 600kg payload. You have to consider the weight of all the other stuff you carry with you. The weight of the rear seats and other bits and bobs in a multispace will mean it will have a lower payload than the van.
Sent from my GT-P3110 using Tapatalk
All so you will have to take your weight in to consideration
Just a thought what about small trailer easy on off Confusedcratch:
Yesterday 05:50 PM
15-11-2026 05:06 PM
15-11-2026 04:54 PM
One thing after another
14-11-2026 10:56 AM
14-11-2026 08:44 AM
