  • 2 Vote(s) - 2 Average
Grinding Noise
Hi thanks to anyone who replies, I have a grinding noise coming from the drivers foot-well when accelerating up the gears it stops when I press in the clutch and you can't really hear it when in 4th and 5th at a steady speed. I have a 06 1.9D forte it is worse at high revs in 1st and 2nd so I was thinking maybe a bracket has broke and the grinding is actually a vibration rattle? Confusedcratch:
If in doubt smash it to bits :woop:
:thumbsup: 2006 1.9D Multispace Forte
You may well be on the right track.Check the engine mounts as 1 may be broken.If it is,my advice is to change them all.3 I believe.:thumbsup:Confusedalut:
Thanks I'm gonna take a look today seen as a great big yellow disk has appeared in the sky, god knows what it is Confusedunny:
[-] The following 2 users say Thank You to jimmyads for this post:
  • RolyG, royboy302
Right I had a look today the obvious engine mount seems ok and the rubber is still intact, the 2nd I presume is under the battery tray? so gonna leave that for another day and the 3rd I don't know, if anyone could point me in the right direction or has a diagram that would be great :brickwall:
Not the engine mounts they're solid back to the drawing board :brickwall:
My immediate thought was a disintegrating clutch bearing.....
Could the noise be coming from the drive shaft bearing ? the one that supports
the drive shaft midway between the g/box and hub?Confusedtudy:
thanks I'll check them soon as I get a better day, I hope I'm getting closer its doin my nut in now, lol
Well it doesn't seem to be the drive shaft bearing, unsure on the clutch release bearing. The noise is still there but I can feel it if I put my foot on the floor under the break pedal. This is certainly testing me now, lol.
Today 08:36 AM
» Replies: 15
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
