  • 3 Vote(s) - 3.67 Average
headlight change
I need to change the headlights on my Berlingo,any ideas how much bodywork has to be removed and if there is anything in particular I need to be aware of.
Many Thanks
Mk 1,2 or 3? It makes a difference if you let us know what you've got.Confusedalut:
  • adam3rdcanvey
It's a Mk 2, first reg. 12/2005 1.6tdi Berlingo Multispace
regards
If it is just the bulbs they can be changed without removing any, you will see two screw off caps and the bulbs are behind them. Just be prepared for a few scrapes on your hands as the passenger side one is a bit of a pain...
If it is the whole unit I had to remove the front bumper and wheel arch lining.
[-] The following 1 user says Thank You to Silent_Bob for this post:
  • bryn
Today 12:33 PM
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
