I've recently bought a berlingo 19d van and need help!
The problem I'm having is starting the engine when it reaches normal operating temperature. The van will start effortlessly when cold ,its only when I've been driving for a while the van fails to start .
Has anyone got any clues to what the problem is?
I've already ruled out a flat battery. . . As mentioned the van is only failing to start once warm.:S:S
Threads: 20
Thanks Given: 2,126
18
Does it turn & fail to start?or does it not turn over?If it doesn't turn over,suspect connections or starter winding failing when hot.How old is the fuel filter?
Strawberry flavoured windows
Threads: 9
Thanks Received: 441 in 402 posts
Thanks Given: 316
15
suspect the starter motor.
Had this before many times
Threads: 50
Thanks Received: 474 in 419 posts
Thanks Given: 744
23-02-2014, 07:52 PM
(This post was last modified: 23-02-2014, 07:55 PM by Ol'Jeffers.)
Tighten all start related cables. Solenoid, starter motor, battery and related earths.
If all of those OK then look at the starter motor. It's almost certainly a temperature related problem but cables get warm too.
(Personally I think that Ron's hit the nail on the head but I'd still be
checking thecables first! Basically 'cause I'm stubborn and don't like spending money.)
