  • 3 Vote(s) - 3 Average
Most electrics gone AWOL
Hi folks, I've just aquired a 2005 (Mk2) 1.9 non turbo van, thats been passed to me as its lights, wipers, rev-counter, heater fan motor and radio have stopped working, just after its previous owner pressure washed the engine. It sounds like a BSI problem, but given the circumstances I'm suspicious of the BSM/Engine fusebox. I believe the power supply to the BSI and various other items go through this. Am I correct thinking there is a PCB below the fuses?
I presume I should have 12v on one side of the fuses and this is where I should start my checks?I assume I should check for any water entry around the BSI in the cab?
Any advise or thoughts would be greatly appreciated
[-] The following 1 user says Thank You to morph for this post:
  • Ol'Jeffers
In the engine bay fuse box (Bsm/Psf) - Check all fuses.
Then check the main Battery fuses which are hidden down the sides of this.
Disconnect the battery before you do this though.
Think you might have to undo the nut clamping the two bits together. :thumbsup:
valeo alternator CL15 rebuild
Today 07:08 PM
Unusual Braking Problem
Today 06:33 PM
Today 06:19 PM
oil Sump
Today 06:18 PM
5 x 18" wheels suit B9
Last Post: raymondinio
Today 04:34 PM
M59 1.4 Petrol question
Yesterday 10:48 PM
Yesterday 09:29 PM
» Replies: 27
Yesterday 09:08 AM
Insurance Shocker !!!
Yesterday 09:04 AM
13-03-2025 08:09 PM
