  • 9 Vote(s) - 2.11 Average
Big ends?
Hi all
I've just bought a 51 plate multispace. When I rev the engine there is a noise that sounds like a big end has gone but it is not consistent and it doesn't seem to be getting any worse, does anybody have any idea what this could be.
Cheers Chris.
Hi again, I'm not that conversant with British auto terms. What is a big end? A main bearing? Thanks
Tom
(19-06-2011, 04:56 AM)3rensho Wrote:  Hi again, I'm not that conversant with British auto terms. What is a big end? A main bearing? Thanks
Tom
Hi Tom,a big end is the connecting rod to crankshaft bearing.
Cheers Chris.
Ahhh, thanks. Conrod bearing in American speak.
@ 3Rensho - Little end connects rod to piston via gudgeon pin and big end shells connect rod to crank.
sent from a telephone that resembles a well known chocolate bar, dosen't taste like it though!
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte.Confusedalut:
Hi guys, bit of an update having spoken to several people the general concensus seems to be that it is the cat that has failed and the noise is the cat resonating in the exhaust pipe.
Cheers Chris.
Get it cut out and replaced with a piece of straight pipe then
(01-07-2011, 07:06 PM)Coco Wrote:  Get it cut out and replaced with a piece of straight pipe then
I could buy an earlier front pipe without the cat but I don't think it would get through the M O T.
Diesels do NOT need a Cat for the MOT - the only test is a "smoke" test
Mine is removed and sailed through the test
(02-07-2011, 04:55 PM)Coco Wrote:  Diesels do NOT need a Cat for the MOT - the only test is a "smoke" test
Sorry forgot to say mines a 1.4 petrol.
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
