  • 6 Vote(s) - 3.83 Average
Notes on alternator belt renewal 04 Berlingo 2.0ltr HDI with AirCon
Lift Bonnet and secure
Loosen R/H side front wheel nuts
Lift front right side of car and secure
Remove front R/H wheel
Remove wheel arch splash shield
Make careful note the route the belt takes around the pulleys!
Belt is tensioned by the upper of the two idler pulleys which is spring loaded (and its a strong spring!).
To release tension, place an open-ended 14mm spanner securely on the pulley nut, then attach a suitable ring spanner to its end to extend it.
Pull down on spanner combination firmly (anti clockwise), the tensioner pulley should swing/rotate releasing tension on the belt (It maybe possible to lodge the spanner while under tension to secure it).
Slip belt from lowest rear pulley (crankshaft) then release tension on tensioner pulley, remove spanner. Fully remove old belt then fit new belt over all but lower rear pulley.
Release tension on the tensioner pulley again (turn anti clockwise again), slip belt over the lower pulley. Release tension pulley and remove spanner.
Carefully check the run of the belt and its lay over the grooved pulleys, especially the alternator pulley, as its quite hidden away.
Replace splash guard then front wheel, lower car, tighten wheel nuts. Start engine, check belt. Close bonnet.
Old belt lasted 100,000 miles and had not failed but starting to shred. New belt is a Gates cost £11 from motor factors.
Attached Files Thumbnail(s)
[-] The following 3 users say Thank You to ebbo for this post:
  • addo, Frosty149, ron
That's just how I did it. Except I forgot which pulleys it went around and in which order. Took me a while to figure it out!
(02-03-2014, 11:48 AM)steve valentine Wrote:  That's just how I did it. Except I forgot which pulleys it went around and in which order
That's exactly where I went wrong!! :brickwall: Hence the attached picture... Smile
I think if you can remember that the two small pulleys that sit between the
large pulleys are the only pulleys on the outside of the belt you can't get it wrong.
2011 B9 DPF warning light
Yesterday 11:52 PM
Fuel Gauge trouble
Last Post: Pricklybuzzz
Yesterday 11:48 PM
Hello
Yesterday 11:43 PM
Any advice regarding boot carpets being wet!?
Yesterday 05:50 PM
» Replies: 21
Yesterday 10:53 AM
Frequent DPF REGEN's
17-01-2025 08:43 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
17-01-2025 02:29 PM
Power flex anti roll bar bushes
Last Post: NANO_Vigo
17-01-2025 10:54 AM
Power flex lower wishbone bushes
Last Post: AD246
17-01-2025 08:54 AM
How to change your username
Last Post: Mike
16-01-2025 11:04 PM
