  • 2 Vote(s) - 3 Average
anyone can help with a leak on my berlingo
hiya
i am about to buy a berlingo of my colleague at work he oringinally asked £3000 howver when he last drove it the temperature guage was about above the normal temprature he filled it up with water into the tank he drove around the block and it was leaking underneath the heater and pressure steam what could the problem be? radiator broken ? blocked radiator? cracked hose? head gasket gone?
any information would be greatfull before i buy it
thanks mike
Any of the above! Hard to say without looking at it!
Run...don't buy it
[-] The following 1 user says Thank You to Bertilingo for this post:
  • philip
I'd be reluctant to buy it unless I knew what the issue was and also if the engine had been severely overheated at some stage, could be expensive.
Good luck
2012 Berlingo XTR 110 in Iron Grey
Money cannot buy you happiness but it far better to cry in Ferrari than on a bicycle
[-] The following 1 user says Thank You to Bigian for this post:
  • philip
thanks the berlingo only done 30,000 miles and i bought a few things of my colleague and everthing is fine he explained to me that he was driving it and it was abit over the normal temperature guage so he filled the water tank up drove around the block checked and all the water was gone he said it was like steam underneath the fan cooler any ideas roughly?
It sounds like the heater matrix is leaking, not a job I would attempt to do Sad
Blocked or failed heater matrix! Is a time consuming and expensive job unless you do it yourself. I would not touch this car unless it was dirt cheap. Sad
so would a new heater do the job?
Unless you know what your doing then i wouldn't touch the car/van. If hes a good friend/colleague then he will know what is wrong with it and say to you.
My other question is why is he selling it?! £3000 sounds a lot for a MK1 with a leaking heater?
I DO MISS MY BERLINGO Heart
(05-03-2014, 09:17 PM)mikeweerts23 Wrote:  so would a new heater do the job?
A new heater wouldn't do the job.
This vehicle is a serious risk and we could never recommend remedies to a problem that is not properly identified. Best advice is walk away... and say thanks but no thanks.
ASDA AdBlue 10 January 2026
Yesterday 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
Blower fan
04-01-2026 09:58 AM
