Changing lower arm balljoint
Threads: 15
Thanks Received: 4 in 3 posts
Thanks Given: 12
Hi
I am now changing the lower arm balljoints on my berlingo
I will add a picture from haynes,
[Image: 24qramt.jpg]
This bolt, are impossible to remove on both sides of my car,
I can remove the nut, from the front, but no way the bolt..
Seems welded.. but question is:
is it just to hit it hard so it slide out, or do i need to screw it out after warming it up? ...before i break anything
'Cus this thing really bothering me.. cus now i'm stucked
My Car INFO:
CITROËN BERLINGO (MF) 1.4 i (MFKFX, MFKFW)
2005 Mod
Volum: 1360 KW: 55 HK: 75 Fuel: Gasoline
Threads: 67
Thanks Given: 1,045
If you can apply some heat (oxy or MAPP torch) it will help. Do you also have something like Wurth "Rost-Off" aerosol spray?
Put the nut back on loosely and use a brass rod with hammer to drive the bolt outwards slightly. If you can rotate it then you are making progress. Rotate in each direction to loosen the crud and eventually it will tap out.
Threads: 15
Thanks Given: 12
So it does not sit in threads?
My Car INFO:
2005 Mod
Threads: 67
Thanks Given: 1,045
No, it passes through an un-threaded hole, with the nut on one side to pull it tight.
Here you can see the bolts: http://www.ebay.co.uk/itm/170960230779
Threads: 15
Thanks Given: 12
08-03-2014, 12:59 PM
(This post was last modified: 08-03-2014, 12:59 PM by Varg.)
thanks, i'll give it go tomorrow morning.
I put it on hold, after 4 hours in garage, and started washing my motorcycle
[Image: d36f4478a6bf11e39c1112d165668c06_8.jpg]
My Car INFO:
2005 Mod
Threads: 20
Thanks Given: 2,126
18
Your dog is obviously avoiding the glare from your bike.But it some sun shades.  :wave:  :whistle:  illyme:
Strawberry flavoured windows
Threads: 15
Thanks Given: 12
heh  it IS shiny
But finally i jumped on the ball joint today, and it was a hassle. The bolt went out after i applied some anti rust on it ( http://www.wd40specialist.com/)
Then the main bolt was stucked, so after a couple of hours i managed to make more space on the swivel hub, and some swearing, and then out, new on in
My Car INFO:
2005 Mod
Threads: 67
Thanks Given: 1,045
27-03-2014, 12:55 PM
(This post was last modified: 27-03-2014, 12:57 PM by addo.)
Usually the swearing is the secret!
This particularly applies when you are caught swearing by someone who should not hear it...
• RolyG
Threads: 15
Thanks Given: 12
(27-03-2014, 12:55 PM)addo Wrote: Usually the swearing is the secret!
It sure does
patience, and swearing.
Btw, when i was under, i saw that the dust-covers on the "steering brace" - right word? (tecnical English is not my strongest side sometimes.) was getting "rotten" Both sides
Time for a change.
Is it a lot of work?
or adjustments i need to do after finishing the job?
[Image: 721%20198_0.jpg]
My Car INFO:
2005 Mod
Threads: 67
Thanks Given: 1,045
In English, the "steering rack gaiters". I think "joints-soufflets" sounds nicer though.
The driver's side is quite easy, for the passenger side you must stretch the rubber over the steering ram attachment stud. Not an easy task and very likely another to have you using the F- and C-words loudly just as your 80-year-old neighbour is walking past...
Ahh bless them...
Yesterday 04:54 PM
Yesterday 04:45 PM
Last Post: stu76
Yesterday 05:41 AM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
