  • 4 Vote(s) - 1.75 Average
berlingo leaking gearoil
could anybody please help i changed the lowerarm and wheel bearing pass side a couple month back just noticed tnite that there a bit of a puddle of oil in garage floor tnight the drive shaft went in as far as it could but it just wasnt quite all the way in should it be goin all way in there a little bit of play if u take screwdriver and lever it a little any help would be much apreciated
If the shaft isn't all the way in, there will be a shines ring visible around the shaft.
I would imagine that you have perhaps damaged the seal, I would get a new seal and fit that.
  • bigbubba85
the drive shaft was hanging down for about 2 weeks so prob is the seal nackered
i ve noticed tonight that the power steering fluid a bit low there is a mess of oil all under the subframe but cant see any burst pipes you can see a drip from the pipe with the gear selector onit
Yesterday 09:56 PM
04-09-2026 05:28 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
Last Post: stu76
18-08-2026 07:16 PM
