  • 14 Vote(s) - 3 Average
Very busy maintenance sunday!
Successful but very busy Sunday!
Cambelt & Tensioner
Waterpump
Thermostat
Idle speed thermostat
Coolant flush and change
Air filter
Fuel filter
Oil and filter (no sump plug disasters)
New 'brighter' headlight lamps
Sent from my GT-I9000 using Tapatalk
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte.Confusedalut:
Hi!
And what about mileage?
You should get your own stamp for the service book :thumbsup:
Good job mate
Wow, that is impressive!!
(20-06-2011, 12:25 PM)Andre Wrote:  You should get your own stamp for the service book :thumbsup:
Good job mate
Andre. Let's make our own stamp, i.e. stamp of our club. And then try to get an authorization of PSA only for Berlingo? Smile
112500 miles. Had a cambelt at 85000 ish which was fitted by the previous owners (family member) local garage. However like a bunch of tossers the pulley or tensioner wasn't changed. I did notice that there was a fair amount of play in the idler pulley bearing so pleased I changed it. I always replace cambelt kit when I get a new car for peace of mind. Mind you I've had this one for 8 months. Not worth not doing water pump for what it costs. As the coolant had to come out did thermostat as well and I needed to do the idle speed thermostat which was knackered and meant tick over was very low when cold.
Yesterday 03:29 PM
Last Post: Triggermann
Yesterday 01:47 PM
15-07-2026 12:17 PM
Last Post: wbchevron
15-07-2026 09:32 AM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
