1.9d clutch change
I have a 2002 partner with 1.9d engine(non turbo). The clutch went bang two days ago so im pulling it to bits myself and wondered if there is any advice out there regarding problems etc. I would also appreciate any advice on sourcing parts and would like to put it back together using some good quality stuff, regards Ken
The LUK clutch kit is OK. Try to avoid the cheaper stuff with Chinese parts. Make sure that the clutch bearing is changed.
  • addo
(11-03-2014, 09:39 AM)Kenny850 Wrote:  I have a 2002 partner with 1.9d engine(non turbo). The clutch went bang two days ago so im pulling it to bits myself and wondered if there is any advice out there regarding problems etc. I would also appreciate any advice on sourcing parts and would like to put it back together using some good quality stuff, regards Ken
new spigot shaft guide/seal.
grease your shaft.dont forget to drain gearbox.may pay you to have 2 of these http://www.ebay.co.uk/itm/Citroen-Berlin..._601wt_721
Thanks Jeffers/Spudd, some sound advice there, its appreciated, Ken
(12-03-2014, 08:39 AM)Kenny850 Wrote:  Thanks Jeffers/Spudd, some sound advice there, its appreciated, Ken
carparts4less are cheapest for your clutch kit,bit cheaper than eurocarparts dont know why looks like same company
and they stock luk kits
dont forget to drain your gbox oil or it will be messy
Leaking windscreen or aerial
Yesterday 08:50 PM
Apple Carplay
02-04-2026 01:26 PM
