  • 2 Vote(s) - 2.5 Average
Cruise control on a 1.9D?
Hey folks
Quick question, is it possible to retrofit cruise control on a 1.9D? Specifically a 600 Enterprise on a 54 plate. All the posts I have looked through seem to be based on the HDI engines.
I have had a look for the brake and clutch switches, the brake has a 2 wire switch and the clutch has none. However there are 2x 2 pin/wire brown connectors lurking nearby.
I have also looked briefly at lexia and the option is there for it in the BSI.
2005 Enterprise 600 1.9D - It did 85 once but started to smell funny.
The bsi is common to both hdi and dw8, however the dw8 uses a mechanical pump, so the ecu cannot rev the engine as a hdi can, so the answer is no bar fitting an actuator and some kind of aftermarket cruise adaptor
[-] The following 1 user says Thank You to dumdum for this post:
  • Silent_Bob
Thanks dumdum, you just saved me £50 as I almost bought a cruise stalk Big Grin
Nail the accelerator to the floor. They're so slow that the occasional touch on the brake will keep you at a constant speed
Malc
Stupid computer!
[-] The following 1 user says Thank You to crickleymal for this post:
  • ron
True.... Make sure your accelerator cable is tight and moving freely... Makes it slower if not!
Sent from my HTC Desire C using Tapatalk
We have a Romahome with a 1.9d engine.
I had an aftermarket cruise control fitted, expensive but some of the best money I have spent.
Peter
(16-03-2014, 07:04 AM)Romahomepete Wrote:  We have a Romahome with a 1.9d engine.
Peter
Which one did you use Peter.
We've just got an old 1.9D 1999 vintage (on our Romahome Duo mini Motorhome) and I really miss the cruise I had on my car.
Last Post: BigVtwin996
Yesterday 12:10 PM
Eolys replacement tank
Last Post: jw4821
Yesterday 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
