  • 4 Vote(s) - 1 Average
citroen berlingo 1.6hdi fumes!
Wink
can anyone advise.
have a berlingo 1.6hdi 2008
seems to have a stong exhaust fume smell coming from inside the cabin area. appears only shortly setting off and gets worse on a longer journey.
ive checked for oil leaks nothing found. leaking towards the pollen filter!
anyone have any ideas please?
many thanks
Check the exhaust for a slight blow.
thanks for the reply. exhaust appears fine!
rear door rubbers?, had this happen on another van before
[-] The following 1 user says Thank You to finny for this post:
  • ron
I agree with finny.Confusedalut:
Check the exhaust around where it fits to the cat they can leak there if it's not a perfect fit fumes come up under the bonnet and get pulled in to the cab with the fan on when it's cold open the bonnet start the car then look in the engine bay to see if the fumes are coming up you can see the fumes better when the engine cold .
Check for leaks around the injectors, exhaust fumes can blow past the seals.
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
