Threads: 52
Thanks Received: 668 in 567 posts
Thanks Given: 145
43
I was called by a neighbour yesterday who was checking his valve clearances prior to timing belt etc change and had a surprise at the results.
Vehicle had covered 100 k miles.
Every exhaust valve clearance was pretty much spot on at 0.30 mm
Every inlet valve was too tight at 0.038 mm against the required 0.15 mm
( 1.5 thou instead of 6 thou )
I have to say I was surprised at the results and double checked the cam position and the feeler gauges, my neighbour was also surprised hence his asking for a second opinion.......
Naturally all will be rectified but I just thought I'd share the story.
Threads: 12
Thanks Received: 384 in 273 posts
Thanks Given: 16
36
I have found that between @ 140k &180k that they close up sufficiently for the engine not to start from cold, makes a huge difference once they are correct again.
My C15 DW8 engine, is ready for its second adjustment at 265000 miles, as the starting issue is becoming noticeable .
Threads: 38
Thanks Received: 31 in 27 posts
Thanks Given: 69
(14-03-2014, 09:27 AM)Lighty Wrote: I have found that between @ 140k &180k that they close up sufficiently for the engine not to start from cold, makes a huge difference once they are correct again.
Are you the lighty from the c15 forum?
Reading this
http://visaforum.freeforums.org/c15-fuel...-t935.html was what persuaded to finally de-EGR my van, and knowing that people had just ripped the flap out the EGR made life much easier. I love a bit of brute force.
MOT passed with no problems, so thanks to you and the other contributors. I never bothered joining just to post asking for pics and to say thanks
2004 1.9D Multispace/Budget crew cab work van!
Threads: 38
Thanks Given: 69
(14-03-2014, 08:47 AM)geoff Wrote: Every inlet valve was too tight at 0.038 mm against the required 0.15 mm
Speaking of EGR's, who wants to bet that bloody thing is responsible for wearing the inlet valves while the exhaust valves remain spot on?
Threads: 52
Thanks Given: 145
43
EGR's ... quite possibly as valve recession is more usually associated with exhaust valves.
Threads: 17
Thanks Received: 117 in 92 posts
Thanks Given: 153
14-03-2014, 11:34 PM
(This post was last modified: 14-03-2014, 11:35 PM by adam3rdcanvey.)
Is true in my opinion. A friend of mine has a dw8 partner 04 reg... EGR disabled from new and crankcase breather vented to fresh air instead of back into the manifold, this means no sticky gunk in no's 1 and 2 cylinders either. Has remained within tolerances and has done 156000 miles now. EGR is a short term solution causing long term engine damage
