Threads: 9
Thanks Given: 6
Hi, sorry if this has been discussed before but how easy is it for someone with a little knowledge to change the fuel filter on a 2005 1.6i diesel Berlingo ?
Just been quoted 120 euros ( in France) to change
All help appreciated
Threads: 3
Thanks Received: 1 in 1 posts
Put "fuel filter" into search I think I used a post by Bingo it takes longer to remove a few parts than to change the filter, it is straight forward job
The following 1 user says Thank You to stevolew for this post:1 user says Thank You to stevolew for this post
• bryn
Threads: 23
Thanks Given: 50
29
Be brave bryn it's not that hard to do once you've done it you'll say to your self why did i pay some one else to do it :thumbsup:
Threads: 9
Thanks Given: 6
is there a bleed valve on the 1.6hdi or is it necessary to fill the filter with diesel?
Threads: 16
Thanks Received: 31 in 22 posts
Thanks Given: 3
I was a bit aprehensive about changing mine but it turned out to be easy. There is a tap on the top & a drain on the bottom of the filter which I assume is for draining off any water that might get trapped in the filter. All you need to do is swap the filter over then pump the priming bulb for a good 2 or 3 minutes.
