Threads: 6
Thanks Received: 4 in 2 posts
17-03-2014, 08:00 PM
(This post was last modified: 17-03-2014, 08:54 PM by delticol.)
Today I changed a worn front o/s wishbone. What a swine of a job. Most bolts came out OK but the main bolt through the front bushes/ subframe was awkward. There is a clip that holds the nut in place, of course this just allowed the nut to turn. I had to cut the wishbone out using firstly an angle grinder then a hacksaw. Eventually it came out allowing me to get a ground down spanner on the nut. Stupid design.... 4 hours to change a wishbone.
Threads: 6
Good idea Ron, mines a bit passed that though as it was 10 years old when I bought it !!!
Threads: 17
Thanks Received: 117 in 92 posts
Thanks Given: 153
(17-03-2014, 09:47 PM)ron Wrote: The only thing I have against it is the taste.
:whistle:
Gets better after the first pinta.....
Sent from my HTC Desire C using Tapatalk
Threads: 37
Thanks Received: 38 in 37 posts
Thanks Given: 11
Blimey that sounds like a right pain, o well at least ill know what ive got infront of me when mine need doing!
Threads: 67
Thanks Received: 454 in 360 posts
Thanks Given: 1,045
Mine took about four hours per side. Twenty minutes to remove, an hour to degrease and scrub, an hour to renew bushes and balljoint; the rest to refit, bounce/roll to find resting position of anti-roll bar, and torque down.
