21-06-2011, 08:48 PM
Hi All.
I recently bought a 07 1.6 hdi and am having a bit of trouble with the engine. When i start it in the morning the van starts on the first turn but runs rough, dosent idle properly and the engine shakes a bit . when i drive the van for about a minute or two it runs fine and idles perfect.
Any idea what might be causing this anyone?
Threads: 32
Thanks Given: 13
When was it last serviced?
Mileage?
Is the EML on or any codes stored in the ECU to give you a clue?
Threads: 17
Thanks Received: 117 in 92 posts
Thanks Given: 153
air in the fuel system.... try the priming pump next to fuel filter housing... pump until firm, start engine and pump a few more times. Have a look at fuel lines for any air bubbles. If you have clear lines??
Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
Thanks, Adam.
Think I have the same problem, but not as bad.
Revs fluctuate (good word!) a little on initial start-up and engine is tiny bit rough sounding. Nothing major.
Once I start off it is fine; goes well, no hesitation and pulls like a train.
Will try your suggestion.:thumbsup:
Threads: 17
Thanks Given: 153
is worth a pump.... easiest thing first eh??
Threads: 0
Try replacing the fuel filter, air can be induced into the fuel filter's rubber seals on the side of the filter, where the in/out let pipes attach. this is the common cause for such a rough running 1.6HDI. INSPECT THE FUEL PIPES AS WELL, ENSURING GOOD TIGHT CONNECTIONS AND ARE OF GOOD CONDITION E.G.NOT BROKEN. LOOK FOR SIGNS OF MOISTURE AROUND THE CONNECTINS / FILTER CONNECTIONS. GOOD LUCK ..
