  • 4 Vote(s) - 3.75 Average
Head Unit Upgrade
Looking to upgrade the existing Continental RD4N1M/03 to an aftermarket head unit with Bluetooth built in.
Given each time I visit Halfords (whom I was going to get to install new) I get a different story on likely issues and parts required, hopeful someone might have a bit experience and advice, and possibly look to do this myself.
All I would like to know is the parts required, and how straightforward it is to replace.
I am hopeful from google searches, two parts being required, an aerial adaptor and canbus interface suitable to the new stereo. Is it just a case of plugging these into the existing connections and then connecting up to the new stereo? Or is it perhaps a lot more complicated. I realise I will look some functionality of the display on the dash, but hopeful this will just be the issue with the clock not being adjusted when it changes? All other functions will work as at present?
Grateful for any advice.
Thanks in advance
Scott
You will lose the display apart from the clock when you change the head.
Are you looking to keep the stalk controls?
Pioneer make good stereos , however don't buy it from halfords , window shop there then get it cheaper online.
You will probably need to change the speakers too as you will notice how crap they sound with a new head unit
[-] The following 1 user says Thank You to homeruk for this post:
  • scottttyyyy
Thanks for the input. When you say I will lose the display apart from the clock, would this include the date and the information ie fuel etc?
Also re the speakers, as it is a work vehicle, on a budget when it comes to doing this, and was hoping to get it done below £200, which is based on the headunit and parts being around the £150 mark, £50 fitting if needed. I suppose I could get the radio done 1st and see how bad it is, as long as it can be heard and handsfree calls better than the portable device I have, may have to just do with it.
I would like to use the stalk adaptor, however, if not no big issue.
Do you know if it is relatively straightforward to do the install? If its just a case of removing, connecting up the new with the new cables, happy to do so, concern being I have heard some cables may have to be swapped to provide a permanent feed.
Take it you have the mk3?
Of course you have , silly me has just noticed where you have posted this.....
Not up to speed I'm afraid on the mk3 hopefully some one will be along soon who has done a swap and can tell you exactly what you need to know.
I do know however all head units swaps are straight forward as long as you have a head for electrics
In my work van i have alpine With steering wheel contorller. Works perfect.
When i press the steering remote next and previous button at the same time. I Get the menu in my headup display.
And if i press the button on the wiperblade contorller i Get the car computer in the display.
Only thing You dont Get is the name of the song/radio You are lisening to in the headup display
Big Grin
(20-03-2014, 10:06 PM)Tikki Wrote:  In my work van i have alpine With steering wheel contorller. Works perfect.
Hello. I want to change my radio also. I like pioneer Avh-x 5500bt. Can i also get in car computer screen like you on pioneer? The only problem is this for me. If i can Enter car computer screen Smile i will buy my pioneer. Thank you
ive changed to a double din kenwood a while ago, the display will not show radio station and you will not be able to adjust time or date, all the other functions like temp mpg etc still work off the stalk, if you need to adjust time/date just pop old head unit in, if you use all the proper replacement wiring kit this shouldn't take more than a few minutes to do, just unplug new wire, plug in power to old head unit
I was looking at replacing the head unit and wondered has anyone added rear speakers to a van?
I already have factory bluetooth and stalk
Yesterday 10:47 PM
Yesterday 09:14 PM
OIL Drip
Last Post: Martinze
Yesterday 06:08 PM
Yesterday 02:49 PM
New owner in Bristol UK
Last Post: JPCoetzee
Yesterday 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 09:32 PM
09-03-2026 05:17 PM
Potential Purchase!
09-03-2026 03:03 PM
Diagbox 7.57 download
08-03-2026 09:13 PM
