rubber bulb for bleeding fuel system
hi
I have berlingo 1.9 diesel 2005 .
I have a problem with air in the fuel system was told to squeeze the rubber bulb until goes hard to push further ,in my car doesn't go hard .do you think I need to change it and is it part of the housing or
separate part ?
many thanks
There are two fuel primers, one is a rubber bulb which sits in the fuel line from the tank, the other is a push plunger which is part of the fuel filter housing. Depends what you have if you need to change the housing.
the car has a push plunger connected to the fuel housing
If it doesn't go hard,check you are not drawing air in.Confusedalut:
(22-03-2014, 08:45 PM)ron Wrote:  If it doesn't go hard,check you are not drawing air in.Confusedalut:
it looks like there is how do I find it
One thing after another
Yesterday 10:56 AM
Yesterday 08:44 AM
12-11-2026 10:15 AM
Last Post: Dyane6
02-11-2026 11:10 PM
