  • 4 Vote(s) - 3.75 Average
door warning light
Big Grin
Hi fellow Berlingoers, i seem to have a problem with my door warning light, it stays on after all the doors are closed and locked when driving, also the interior light stays on unless i manually switch it off which is no use when it is dark outside and i open the doors to get in, could any one tell me how to fix this please. Its an X reg 5 door multispace. Thank you Sad
I would suspect the wiring to the door where flexing with frequent opening/closing may have shorted,OR the sw itself has gone to earth.Confusedalut:
  • bigbob
Thanks Ron have check the wiring and there does not seem to be any breaks in it , but i took out the plunger/door switch , and there were no wires attached to the two prongs so i'm thinking i'll need to investigate it further but the hole is a tad small :-s
That's not a common complaint.:whistle::whistle:RolleyesCan you access from the rear of the pillar? If not,a bit of bent wire can sometimes persuade the wire to appear.Good luck.
[-] The following 2 users say Thank You to ron for this post:
  • bigbob, joemc20
Hahahaha cheers Ron will try the bent wire trick, cheers big man
You're welcome,just don't shake the wire around,fish gently.:thumbsup::whistle:
(24-03-2014, 07:52 PM)ron Wrote:  That's not a common complaint.:whistle::whistle:RolleyesCan you access from the rear of the pillar? If not,a bit of bent wire can sometimes persuade the wire to appear.Good luck.
i too have the same problem but cant seem to find fault,, can anyone tell me what colour wires i should be looking for so i can isolate them.... in a huff :brickwall:
Bit of a zombie thread but same in mine- interior lights stay on, warning light on when all doors shut and no wires connected to switches! What colours am I looking for to go to the door switches?
M59 1.4 Petrol question
Yesterday 10:48 PM
Yesterday 09:29 PM
» Replies: 27
Last Post: MariusTeamPP
Yesterday 07:01 PM
Yesterday 09:08 AM
Insurance Shocker !!!
Yesterday 09:04 AM
13-03-2025 08:09 PM
How rare is my berlingo
Last Post: Gadgetman
13-03-2025 02:30 PM
Official Citroen internal child monitoring mirro...
13-03-2025 10:31 AM
Anti corrosion spray
12-03-2025 02:35 PM
Rubber pipe in engine bay
12-03-2025 10:16 AM
