Lexia Software
Threads: 35
Thanks Received: 119 in 88 posts
Thanks Given: 3
4
Just bought a Lexia 3 and I'm currently installing the software on my laptop
If anybody is contemplating doing the same, put aside quite a few hours because the software installation is soooooooo sloooooooow!!!!!
Started at 4:30pm and it's now 8:25pm and it's still going
I'm an IT Technician and I've never seen any software install as slow as this
The main istallation is from a 1.09GB iso file, so it has to be mounted and then extracted
The process appears to extract to a temp folder and then runs itself from the temp folder while at the same time it installs itself to the same temp folder before copying to the c:\app\lexia folder
Hope it's finished before I go to bed :brickwall:
Threads: 20
Thanks Given: 2,126
18
24-03-2014, 10:43 PM
(This post was last modified: 24-03-2014, 10:45 PM by ron.)
I dodn't understand any of that.I just wish steam would come back.:whistle:
Strawberry flavoured windows
Threads: 35
Thanks Given: 3
4
(24-03-2014, 10:43 PM)ron Wrote: I dodn't understand any of that.I just wish steam would come back.:whistle:
Thought you were going to say horse and cart
But hey, it finally finished at 11:25pm, I can go to bed now
Threads: 20
Thanks Given: 2,126
18
I'm not a technophobe you know.  :whistle:
Threads: 6
Thanks Received: 5 in 4 posts
25-03-2014, 11:19 PM
(This post was last modified: 25-03-2014, 11:21 PM by tommy1.)
(24-03-2014, 08:35 PM)ntm1275 Wrote: Just bought a Lexia 3 and I'm currently installing the software on my laptop
hi
i installed my lexia 3 last week ,i installed on a old laptop with a fresh version of windows xp and took about an hour,trick is to copy the lexia folder on the cd to a new folder on your desktop ,this takes about 10 minutes then open the copied folder you will see setup ,double click this and sit back,click the usual agree to this,that and install to default c/program files etc
i tried to install on main laptop with win 7 32 bit but wouldnt install kept coming up with a error so had to find my daughters old laptop and installed fresh copy of xp and was installed straight away
xp is the best version with lexia 3
other ppl claim win 7 works but i failed miserably
hope this helps cos it is a really good program,it tells you everything
forgot to mention i used daemon tools to run the image iso,then copied the lexia folder etc
Threads: 35
Thanks Given: 3
4
26-03-2014, 12:11 AM
(This post was last modified: 26-03-2014, 12:26 AM by ntm1275.)
In the end, after all those hours, the software failed to install properly, so I wiped the drive and installed a clean version of XP SP3
Like you said, it was much quicker this time - took about an hour, but yesterday I felt like throwing the laptop out of the window
I'm now in the process of installing the updates from 7.02 to 7.36
I did go through a test installation process on my main i7 PC with a virtual XP using VirtualBox to get used to the sequence of the installation as the instruction I had were not very good and came on a single piece of paper and appeared to be written by someone who English was not their first language - it installed on that in about 20 minutes
Just got to learn how to use it now
Which version of the software are you using and do you have any idea how to increase the time for EcoMode from 30 minutes to something longer
Threads: 6
26-03-2014, 12:57 AM
(This post was last modified: 26-03-2014, 01:03 AM by tommy1.)
(26-03-2014, 12:11 AM)ntm1275 Wrote: In the end, after all those hours, the software failed to install properly, so I wiped the drive and installed a clean version of XP SP3
hi
i updated to diagbox v7.34
i only used mine once to diagnose a bsi fault and it picked up couple more faults but all sorted now,not had a look at the eco mode setting so cannot help you there but im sure its been talked about on this forum in the past,try searching eco mode or similar or ask rustcat he really does know his stuff
i had little bit trouble connecting to my van with the lexia plug,had to start software then when the box popped up saying something like identifying vehicle i had to unplug and plug back in then it worked,i read this somewhere else ,google lexia 3 connecting problems and you will find it
Threads: 0
Thanks Given: 1
29-01-2015, 03:49 AM
(This post was last modified: 09-02-2017, 02:03 AM by Liliflower.)
(26-03-2014, 12:57 AM)tommy1 Wrote: (26-03-2014, 12:11 AM)ntm1275 Wrote: In the end, after all those hours, the software failed to install properly, so I wiped the drive and installed a clean version of XP SP3
hi
it updated to diagbox v7.76
installation steps with pictures
http://blog.obdii365.com/2016/05/08/inst...box-v7-76/
Threads: 35
Thanks Given: 3
4
I've only got the software to v7.34
If you have a copy of any updates to take it to v7.57, I would be interested in getting a copy
Today 10:15 AM
10-11-2026 08:36 AM
» Replies: 15
Last Post: Dyane6
02-11-2026 11:10 PM
24-10-2026 08:09 PM
