  • 2 Vote(s) - 2.5 Average
Heater resistor location Mk2 1.6 16v multispace
The usual Berlingo of death full speed only is going on right here, I've had the heater blower motor out and the resistor is'nt visible on any part of the motor casing, there are plenty of threads on here for the aluminium "bannana" shaped transistor pack type, but i cant see anything for what i assume is this type.
http://www.ebay.co.uk/itm/Heater-Motor-R...461c468cb6
Any one come across these? Or do i just need to get back under the dash after going to Specsavers?
(25-03-2014, 11:09 PM)ulysses Wrote:  The usual Berlingo of death full speed only is going on right here, I've had the heater blower motor out and the resistor is'nt visible on any part of the motor casing, there are plenty of threads on here for the aluminium "bannana" shaped transistor pack type, but i cant see anything for what i assume is this type.
this resister is located just above the blower motor housing ,just slide it up and it will pop out,it has a white power plug attached to it
very easy fix ,go to maplins or any other good electrical component shop and buy 1 x thermal fuse i think the ones i bought were rated at 150c
the fuse on the end you can just cut it off and very carefully solder the new one in its place,took me 10 minutes,i have done lots and works every time,you can get crimps if you dont want to risk soldering because there is a chance you will blow the fuse
they cost about £2 each in maplins
[-] The following 2 users say Thank You to tommy1 for this post:
  • BlueSlug, ulysses
I think.... the banana shaped resistor pack is only on the air con model.
Has your car got air con?
No, no Aircon,
Thanks Tommy, i'm skilled at soldering so will definitely give your fix a go!
Your description as a thermal fuse also now makes perfect sense, as the motor brushes had also worn and were showing high resistance...
Cheers guys
Great information thank you. Would this thermal resistor be the same as the one used on the Modutop rear blower by any chance?
0 to 60 - be patient, 0 to 100 - not in my lifetime! :eek:
It may be a slow Blue Slug, but it"s the only slow Blue Slug that I own :S
Today 12:33 PM
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
