Threads: 10
Thanks Received: 5 in 4 posts
Thanks Given: 24
27-03-2014, 06:33 PM
(This post was last modified: 27-03-2014, 06:34 PM by Silent_Bob.)
Hey folks
I am currently being driven insane by the passenger side droplink knocking. I am going to have a go myself but the Haynes manual basically says "remove it and refit it" as far as instructions go.
Just a couple of questions of one of you guys could help out.
Do you have to do them in pairs (i.e like coil springs)?
Is it just a case of removing the 2 bolts and fitting a new one? I don't trust haynes as they are evil.
And are there any pitfalls?
Cheers
Pete
2005 Enterprise 600 1.9D - It did 85 once but started to smell funny.
Threads: 67
Thanks Given: 1,045
Jack up the front evenly or it will be a pig to change, due to the preload on your ARB.
Have vise-grips handy, if possible also a die grinder or Dremel type tool with slitting disc.
• Silent_Bob
Threads: 10
Thanks Given: 24
Cheers addo, I take it sticking it on a pair of axle stands will be ok?
Threads: 32
Thanks Given: 13
Yes, as long as both wheels are off the deck...
Better doing both but not essential if only one is gone, but the other might not be far behind it.
I changed both of mine the other week. It's a quick job and both bolts came off easily, but then it's the second time I have changed them.
The following 1 user says Thank You to tucker for this post:1 user says Thank You to tucker for this post
• Silent_Bob
Threads: 12
Thanks Given: 16
37
Make sure you purchase decent ones, the cheap ones only last a matter of months.
Threads: 10
Thanks Given: 24
Thanks a lot guys, I've looked on euro car parts and they offer 2, one is about £22(TRW) and the other is £12 (Ocap) think I'll go with the TRW ones!
I also could live the rest of my life happily without seeing a squished red human, so axle stands it is!!
