Thanks Given: 1
I have bought replacement rubber mount.could someone tell me how to fit it?
Threads: 48
Thanks Received: 272 in 229 posts
Thanks Given: 4
20
Use lots of dishwashing liquid...
The stuff is the only reasonably 'clean' way of getting the mounts onto the hooks.
Do you have access to a proper garage with a high lift or a pit?
If not, get yourself one of those 6wheeled boards to lie down on.
The () clamps...
It may be tempting to place one above the pipe and the other under.
(Makes it easy to tighten them up)
Don't...
They need to be mounted vertically with one on each side, and a screw on top and bottom. That way, water can't collect inside the clamps.
(you don't want rust there... )
Threads: 67
Thanks Given: 238
50
The other two holes are to allow the mounting to flex without failure.
WD40 works as a lube but it dries quick so may need another squirt if you work slowly.
Serieal Berlingo owner
• garycurrie
Thanks Given: 1
thanks,managed to get the blighter on.
I lubed then hung rubber from chassis bracket,then inserted large slot screwdriver into hole for exhaust bracket and levered screwdriver .lubed exhaust bracket and with a bit of a wrassle slipped it on exhaust bracket.
Threads: 23
Thanks Given: 50
29
Hello Gary welcome to the forum good to see you got it sorted :thumbsup:
