1.6hdi turbo oil feed pipe
I`m giving my 2007 Berlingo Van a bit of love this week and would like to swap the Turbo Oil feed pipe when I`m replacing the oil/oilfilter.
As I`m also replacing the Cat heat shield which is loose can someone tell me if the Oil feed pipe is swappable without removing the turbo? I can`t seem to see any comments or guides so appreciate any help.
Many thanks,
Mark
Hi, I removed the filter from this pipe couple of weeks ago the turbo stays in place. I removed the radiator because i was changing the coolant anyway.(rad can stay in place)but is extremely tight when removing the heat shields and catalytic converter or DPF.
As V6BOY said, you can leave the rad in but you have to remove the exhaust from the turbo and let it flex forward to allow access to the oil pipe where it enters the block. This includes removing the heat shield.
Well my heatshield has started to disintegrate so I`ve a complete new one to put in.
sliding door panel removal
Last Post: mojito
Yesterday 07:35 PM
XL tyres
Yesterday 06:57 PM
Last Post: deejay_xb
Yesterday 10:06 AM
» Replies: 32
Unusual Braking Problem
Yesterday 07:57 AM
Outer cv boot replacement
22-03-2025 10:13 PM
22-03-2025 10:02 PM
Diagnostic Plug
22-03-2025 09:55 PM
22-03-2025 09:52 PM
Rumbling Noise 55-65mph
22-03-2025 09:47 PM
Last Post: Beaumotor
21-03-2025 04:38 PM
