  • 1 Vote(s) - 1 Average
Replacing oil cooler
My son's mk 1 has a lot of oil in the water header tank, a lot! He's assumed the oil cooler is bust and has bought the replacement. Does anyone know whether the water coolant side will need to be cleaned, and if so how?
Are you sure it's not a head gasket failing?
Either way, the oil will rot your durite, radiator flushes will remove much of the oil. I recommend removing all rubber hoses and scrubbing them inside much as possible after a couple of flushes.
(29-03-2014, 06:22 PM)addo Wrote:  Are you sure it's not a head gasket failing?
Thanks for the advice. Wouldn't be sure yet whether it is the gasket, but the whole sump has ended up in the water so he thinks the cooler is most likely. What is durite?
You can flush all the oil out with a washing powder and water solution, or forte bio degreaser or dae eco radiator flush. It will take a few weeks to get all the oil out though, flush weekly.. is a mission!
Sent from my HTC Desire C using Tapatalk
Chuck a dishwasher tablet in the header, plain water with no antifreeze, run for 20 miles then drain down and flush
refill with antifreeze/ coolant
08-10-2026 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
