  • 3 Vote(s) - 2 Average
Wing mirror replacement
I need to replace my passenger side outside mirror (on coming traffic crossed over into my lane and I had to take evasive action and smacked it against a sign). I've got the .mht file that shows how to replace the mirror but it doesn't say how to remove the black plastic boxy bit on the inside of the door that covers the screws and electrical connections. Has anyone done this??? Just a simple careful pry off?? Thanks in advance.
Tom
(29-03-2014, 04:01 PM)3rensho Wrote:  I need to replace my passenger side outside mirror (on coming traffic crossed over into my lane and I had to take evasive action and smacked it against a sign). I've got the .mht file that shows how to replace the mirror but it doesn't say how to remove the black plastic boxy bit on the inside of the door that covers the screws and electrical connections. Has anyone done this??? Just a simple careful pry off?? Thanks in advance.
Tom
Hi 3rensh,
Tom
Hi 3rensho,
Yes you slowly pry off the cover there are 2 fasteners at its base as you try and take this cover off you will see them if you look inside. The mirror housing is held in place by 3 torque screws but I hink you will have to take the door trim off as the lower two are below the trim I have had to take the black cover off as I had a leaking door mirror at the tip of the housing hope this helps
photoman06
[-] The following 1 user says Thank You to photoman06 for this post:
  • 3rensho
Thanks for that. I'll research taking the door trim off. I'm not the handiest working on modern motors :lol:
Last Post: IKUN
Today 06:34 PM
Remote key fob window function?
Today 05:58 PM
Today 05:48 PM
Halp, me van had died :(
Last Post: ae3
Today 05:43 PM
Drop in fuel economy
Today 09:38 AM
rear washer fires front?
11-01-2025 05:03 PM
knocking from rear
11-01-2025 04:51 PM
Berlingo in disguise..
Last Post: BlackPartner
11-01-2025 09:47 AM
» Replies: 34
Frequent DPF REGEN's
11-01-2025 08:59 AM
How to change your username
Last Post: Blakey
10-01-2025 08:06 PM
