Threads: 5
Thanks Received: 3 in 3 posts
Thanks Given: 4
I'm about to change the fuel filter on my 07 1600hdi.
A mate told me I should take it to a garage to be done as the system has to be re-primed.
Is he right, or could I do this myself? He's got me worried now.
If it is a job I could do myself, how do I go about doing right.
Oh yeah! Can't seem to find a workshop manual anywhere. Are there any about? Cheers.
Threads: 32
Thanks Given: 24
On the 2.0HDi it's a case of undo the fuel pipes and unscrew the top of the housing. Drop a new one in replace and tighten the housing and reconnect the pipes. To bleed it, squeeze the rubber bulb/grenade like thing until it goes hard. Check yours and see if you have anything like that attached in the fuel lines anywhere. Be SCRUPULOUSLY clean!!!
Threads: 32
Thanks Given: 24
Certainly on the 2.0 it's under the cover, near the filter and in the fuel lines
Threads: 5
Thanks Given: 4
You are a star Ron. Many thanks.
Thanks Received: 12 in 9 posts
Thanks Given: 12
No problem bingo...Maybe add any tips when you have ago at it yourself..:-)
Ron.
Threads: 5
Thanks Given: 4
A quick question. In photo 4, I see the fuel primer and the fuel line which is connected to it, but what is the other pipe that runs along side it? Many thanks.
Threads: 8
Thanks Received: 6 in 6 posts
Thanks Given: 1
21-02-2014, 06:35 PM
(This post was last modified: 21-02-2014, 06:35 PM by Vossy1.)
Bringing this back to life.
Row, great post, very helpful but I have a query as I'm about to tackle the fuel filter replacement. When priming you say to just squeeze the priming bulb until it becomes hard to compress, sounds very simple, but my Haymes manual says (if you don't have a specialist connecting pipe to return priming fuel to the tank) to fit a length of tube on the fuel outlet of the filter and prime until fuel runs through and then connect the outlet back to the fuel line...which is it or is it either...I prefer the ease of your description...lol
