  • 1 Vote(s) - 2 Average
Oil Change
Hi,
What is the opinion please of the forum to the best mileage to change oil and filter on the mk3 1.6 2010 hdi I see that the view has been to change at 6500 - 8000 miles rather than the 12500 in the schedule what does everyone think? I was going to change every 6250 half way through with the recommended oil Total Quartz Ineo ECS 5W30 can I please ask your views looking forward to any feedback
Regards
photoman06
On my 2010 XTR I have been changing it every 3000 miles, but this is only because the previous owner had it changed every 12000
I wanted to make sure that the inside of the engine was cleaned of any carbon deposits
Once my first year is up, I will change it every 6000 miles
[-] The following 1 user says Thank You to ntm1275 for this post:
  • photoman06
(30-03-2014, 08:30 PM)ntm1275 Wrote:  On my 2010 XTR I have been changing it every 3000 miles, but this is only because the previous owner had it changed every 12000
Thanks ntm1275 that is noted thanks for your reply
photoman06
Lot's off sort run's and cold starting 6000 mile's or 1 year. Long run's with engine up to temp 8000 mile's or 1 year
  • photoman06
Much as it pains me,I agree with Jed.Rolleyes:whistle:
  • photoman06
Doing mine every 6000 in between the normal services.
[-] The following 1 user says Thank You to jamesg for this post:
  • photoman06
Every 5000 in my 1.9D. Probably over kill with the journeys I do now compared to years ago when I just did local journeys but of all the habits I've got it's the least harmful Big Grin so every 5k it is. Cheap and easiest to DIY I've ever owned.
2004 1.9D Multispace/Budget crew cab work van!
use a good quality oil then you shouldn't need to change it earlier than the manufactures recommendation?
I DO MISS MY BERLINGO Heart
Cannot take chances with the HDi motor -change it as early as you like and use the recommended oil with a genuine filter.
6000 is the sensible point.Check the injector bolts for tightness and allow the engine to warm before setting off.Dont blip the accelerator as you switch off.
If you get turbo failure after that then it wasnt your fault.
Mini1275 is on the money by cleaning his motor gradually
  • photoman06
Yesterday 02:51 PM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
