Thanks Given: 4
23-06-2011, 03:30 PM
hi there, i'm trying to find out what a symbol on a citreon berlingo 2.0 hdi van means. its on the attached link.http://i652.photobucket.com/albums/uu250/benjamman/flash.jpg?t=1277813536 ive searched the internet all day and cant find an answer can you help me.
Threads: 52
Thanks Received: 82 in 67 posts
Thanks Given: 9
There is a mk 2 manual scanned on here somewhere which should tell you for sure, but it looks like the oil level
The following 1 user says Thank You to Chris for this post:1 user says Thank You to Chris for this post
• vstundon
Threads: 52
Thanks Given: 87
5
Had a gander at my Mk 3 manual but alas nothing similar
The following 1 user says Thank You to 3rensho for this post:1 user says Thank You to 3rensho for this post
• vstundon
Threads: 32
Thanks Given: 24
This is alongside a series of either small dashes -------- or blocks of similar size at the base of the speedo.
It does indeed indicate the engine oil level.
If it's all dashes - as above - you need more oil !! If it's all blocks you have full oil level
The following 1 user says Thank You to Coco for this post:1 user says Thank You to Coco for this post
• vstundon
Threads: 41
Thanks Given: 82
6
Or you could have an oil indicator that varies so wildly it isn't worth taking any notice of.
The following 1 user says Thank You to Mike for this post:1 user says Thank You to Mike for this post
• vstundon
Threads: 63
Thanks Given: 410
(23-06-2011, 10:00 PM)Mike Wrote: Or you could have an oil indicator that varies so wildly it isn't worth taking any notice of.
Thank you !!!!
I have already got one on mine....
mentioned in previous topics, if I park on a slope or with one side higher than t'other I get the flat dashes showing on the display so must be ridiculously sensitive but not accurate or just plain ridiculous.
As time passes and the joy of ownership gets longer, I tend to take less and less notice of the confounded thing...
