  • 2 Vote(s) - 3.5 Average
Fault codes
Can anyone help me with these codes please?
I`m suspecting EGR valve or Solenoid ??????
P0299
P3008
P0100
Attached Files Thumbnail(s)
Have you looked at http://www.obd-codes.com/ ?
I`ve also got an odd sound which is almost like air leaking when under load so hoping a split hose. Thought it was the loose turbo/cat heatshield but obviosly not!
Here`s a thought.....would a leaking exhaust downpipe cause my problems? The van runs fine albeit a bit more sluggish than normal, no black smoke but has an odd noise from the engine bay which I thought was a blowing exhaust but not sure. Can`t do much investigating until later in the week.
P100 Mass or Volume Air flow Circuit Malfunction
P0299 Turbo pressure regulator.
P3008 flowmeter, airflow not pausable (max value)
They could all be caused by a split hose...
been out this morning and my escaping gases noise is coming from BEHIND the engine. Somewhere under the airbox...
Brake problems again!
Yesterday 08:47 PM
CITROEN VIRTUAL SERVICE MANUAL ALL MODELS
18-06-2025 05:34 PM
» Replies: 33
P0691 P0693 cooling fan circuit problem
18-06-2025 07:32 AM
Does My Van Have A Tracker ?
Last Post: Mark604
17-06-2025 03:01 PM
Last Post: Cumbrian
15-06-2025 09:02 PM
14-06-2025 10:57 AM
» Replies: 36
Last Post: Vlad
12-06-2025 02:36 PM
11-06-2025 10:29 PM
Limp mode, no other symptoms.
Last Post: KiwiMurfy
11-06-2025 10:33 AM
Nearside Headlamp bulb change
10-06-2025 01:59 PM
