  • 3 Vote(s) - 2.33 Average
The new project work van
Smile
Fitted coilovers out of my old 306 the ta technix ones , wound down about half way at the minute
Attached Files Thumbnail(s)
Hello M44 welcome to the forum good to have you with us :thumbsup:
Ordered sum 16" inch 7j steelies , came today , hoping to get these fitted at weekend and lower the rear , fit sum 165/40/r16 tyres for a nice stretch Smile
(02-04-2014, 09:00 PM)Jed Clampit Wrote:  Hello M44 welcome to the forum good to have you with us :thumbsup:
Not 100% sure on how to use the forum it's a first time for me on one but any help be appreciated , thanks
Your doing just fine keep looking around you'll soon pick it up i like wide wheels i'm not into stretch tyre's but it's fine you'll find some of the reply's come a laugh Smile
Looking good!
[-] The following 1 user says Thank You to Alexthekid for this post:
  • M44adidas
looking well so far
project "black and decked" my bagged mk3 berlingo
[-] The following 1 user says Thank You to creith34 for this post:
  • M44adidas
So mite finally get to make some progress , 10mm spacers up front and 20 mm spacers for the rear , going to be using these studs with thread lock , should be safer don't want them to fall off lol
And done a test fit the front
Test fit on the front
And on the rear , got some poke > Smile now to get tires fitted ... up for mot at end of month so after that will need to lower the rear axle , done this before on a 306 but the van axle is different slightly confused how to do it , any help would be appreciated
And a test fit on the rear got sum poke > Smile just need sum tyres now ... she's up for mot at end of month but will be lowering the rear axle after , done this before on a 306 but the van is different is confusing me , any help would be appreciated
Posting things twice because they disappear then come back Confusedillyme:
Wink
Think it will come together nicely , but with coilovers all the way down the tyre hits the adjusters on the coilover , went for 185 /50 / r16 only got two tyres for a fit but going for a 165/40/r16 up front and 20mm spacers up the front to clear this , prop will stick the 10mm spacers on along with 20mm spacers I have for the rear to get some more poke at back
(08-08-2014, 09:19 PM)M44adidas Wrote:  Think it will come together nicely , but with coilovers all the way down the tyre hits the adjusters on the coilover , went for 185 /50 / r16 only got two tyres for a fit but going for a 165/40/r16 up front and 20mm spacers up the front to clear this , prop will stick the 10mm spacers on along with 20mm spacers I have for the rear to get some more poke at back
Done a photoshop of how will look with rear lowered
Liking where this is going. Are the helper springs still on? Maxxed my TA Technix out but the front doesn't sit as low as yours.
'04 Peugeot Partner HDi LX. Lows, Leaks and Wellers. Now matt grey and dent free Smile
Enjoying this thread, slammed look works
sliding door panel removal
Last Post: mojito
23-03-2025 07:35 PM
XL tyres
23-03-2025 06:57 PM
Last Post: deejay_xb
23-03-2025 10:06 AM
» Replies: 32
Unusual Braking Problem
23-03-2025 07:57 AM
Outer cv boot replacement
22-03-2025 10:13 PM
22-03-2025 10:02 PM
Diagnostic Plug
22-03-2025 09:55 PM
22-03-2025 09:52 PM
Rumbling Noise 55-65mph
22-03-2025 09:47 PM
Last Post: Beaumotor
21-03-2025 04:38 PM
