buying a berlingo
Hi everyone
Is aircon worth holding out for as i am finding it hard to find on most Berlingos , have been looking for a desire 2lt hdi model .
I even put a deposite on one  but the dealer could not fix the airbag light or find the spare key :evil::evil:
May end up going for 1.6 desire model up to 2005 ish
dimplex
Threads: 5
Thanks Received: 5 in 5 posts
Thanks Given: 8
Hi Dimplex, I have got aircon on my 03 plate 1.9 d multi and never use it, just open the windows. When i use the aircon watch the MPG go AWOL
Multispace 1.9D Mystery Machine.
Threads: 52
Thanks Received: 82 in 67 posts
Thanks Given: 9
Hi Dimplex, I have got air con and use it all the time, and wouldn't buy one without it. Great in the summer as the Berlingo gets very hot with the amount of glass, and stops windows misting up in winter. Less reduction in MPG than opening a window.
Threads: 52
Thanks Given: 87
5
24-06-2011, 05:12 AM
(This post was last modified: 24-06-2011, 05:29 AM by 3rensho.)
I've got aircon as well and use it frequently when the temps are in the upper 20's to 30's. So far doesn't seem to have much of an effect on mileage. My wife, who always used to complain about aircon in buildings she worked in, loves it in the Berli.
Threads: 80
Thanks Given: 25
Hi MATEY, I`m a bugger for watching my mpg and using the air con hardly makes a difference, I do wonder why as previous cars I have had with it do suffer? Is it really air con? I think not , well not as one would get in an expensive car, there is no real temperature control, in a Rolls you can turn it to desired temperature. BUT it does cool car down nicely when its hot, REMEMBER those odd hot days we get, was it last year or year before?
buy one with, be patient, it will be worth it.
Pete
2010 artic silver VTR with EXTRAS.......  unny:
Threads: 15
Thanks Given: 46
5
24-06-2011, 07:19 AM
(This post was last modified: 24-06-2011, 07:29 AM by Opensauce.)
Aircon comes with a cost. My current Berlingo has it & I like it, but I suppose I shall have to get it serviced at yr 3 next service at £80 cost. My dealer 'recommended' it was done at yr 2 service but I'm hoping I can get away with every 3yrs. If pump fails it costs several £100s to repair which is why many older cars have non working a/c.
This is the first car I have had with a/c & you certainly appreciate it when its really hot like in southern France but truth is how often do we get the sort of weather where a/c is essential? If you buy a car several yrs old with a/c first make sure it works, the air blast should feel really cold with your hand over vent. If it don't & the seller says "it only needs a recharge" it will be because the gas has leaked out which suggests it will need repairs as well.
When the airbag light stayed on on my previous 2005 'lingo it was just the on/off switch in door frame that needed replacing.
2 types of aircon. The simple 'on or off' as in the Berlingo or 'climate control' as fitted in higher spec cars & available as option on XTR. With climate control the aircon runs all the time & works in conjunction with heater allowing constant temp to be maintained. Microprosessor controlled so more to go wrong.
The 'aircon increases fuel consumption' is only relavent in driving in heavy traffic because on't open road in hot weather you would otherwise drive with window open & increase drag so no different to aircon.
Threads: 9
Thanks Received: 28 in 21 posts
Thanks Given: 18
24-06-2011, 10:59 AM
(This post was last modified: 29-08-2011, 12:15 PM by Northman.)
Probably worth if for most people, though it does depend on how much you personally like / dislike heat. As Chris says, there's a lot of glass in a Berlingo, especially if you have a modutop.
I don't have it, but I'm in the North of Scotland, and so only miss it about 5 days every year. (And last year, we had such a poor summer that I didn't miss it at all!  ) But if I lived south of the Tweed, I'd want aircon.
Threads: 5
Thanks Given: 8
My aircon must be playing up as when it get used it saps the diesel juice.
Threads: 12
Thanks Received: 27 in 21 posts
Thanks Given: 31
I have the switch in mine but no AC system. It works a treat LOL
Threads: 20
Thanks Given: 2,126
18
(23-06-2011, 10:09 PM)Pitman Wrote: Hi Dimplex, I have got aircon on my 03 plate 1.9 d multi and never use it, just open the windows. When i use the aircon watch the MPG go AWOL
I can honestly say that using aircon on my 1.6 HDI makes no noticeable difference to MPG.Having just returned after a 2000+ mile trip around Germany using a/c frequently,my MPG stayed the same as normal
Strawberry flavoured windows
Newbie
Last Post: Vmkst
Yesterday 08:48 PM
MyBerlingo App Service History
Last Post: Requiem
13-02-2026 10:43 AM
Mk 3 K9 blower not working
12-02-2026 04:57 PM
Diagbox 9.91 free download
Last Post: Slowmo
11-02-2026 06:29 PM
Last Post: Slowmo
11-02-2026 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
