[Steering & Suspension] Pulling left
I bought a new berlingo 3 weeks ago, when driving it keeps pulling left. Anyone experience this problem? Any advice on getting it repaired. Thanks
Since it's a new auto I'd head straight back to the dealer and tell him to sort it.
Have you checked the tyre pressures , I found all of mine were under inflated causing pitching and rolling .
Two front at 32 psi
Yes, I had the same problem. First step was to make sure all the tyre pressures were correct, that made things much better, though still not quite right. At the next service (at an independent Citroen specialist) had the tracking checked which was ok, but they swapped the wheels around which further improved things so that its just about ok now.
Same problem for posted a thread, mine 2012 going back AGAIN next week full system test with Citreon has they can't sort it at the garage tracking issues. You are in a long stressful time I'm handing mine back once term is up!!
I find to resolve mine by changing the steel wheel to the rear. Ideally I should replace it as sometimes I forget and put it back in the front. It's not a big deal.
just on the subject of the berlingo pulling to the left my father in law bought a new mercedes which pulled to the left, after countless trips back to the dealer he went to an independent and they said it pulled to the left due to the geometry being set up for the roads on the continent. He got it finally got it sorted by the main dealer fitting a small kit to the suspension to correct the geometry. Would this be the same case for the berlingos that most seem to pull to the left?
#13 Less than 1 minute ago
Email dom@flametv.co.uk he doing a program on these issues, don't get done get Dom, citroen say they have never heard or recieved any complaints but this forum has highlighted them, some cases are worse than others.
Mine tends to pull slightly to the left & when I drive in Europe it tends to pull slightly to the right so I guess its just running down the camber.
Today 04:31 PM
Today 11:13 AM
Last Post: JPCoetzee
Yesterday 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
