Threads: 9
Thanks Received: 2 in 1 posts
Well lads yous might tink i have a few bolts loose in my head but am considering converting the fronth strits onto xantia hydrolics. Just wondering do any of you lads know if xantia hydrolic struts will fit a mk2 berlingo also will the power steering pump from xantia fit onto berlingo engine or will it need some modding??
Appricate any feedback cheers!!
Threads: 67
Thanks Given: 238
50
No bolts loose just a chap having a bit of fun and enjoying his vehicle ! Sorry I cannot help but good luck and keep us posted, sounds interesting.
Serieal Berlingo owner
Threads: 21
Thanks Received: 28 in 23 posts
Thanks Given: 26
sounds interesting! thinking about hydraulics of bags for mine sometime down the line
project "black and decked" my bagged mk3 berlingo
Threads: 9
Cheers lads! :L will keep yous posted how i get on!
Threads: 67
Thanks Given: 1,045
The strut mount as made, is too high for a Xantia strut top to fit - you would need to cut holes in the bonnet. It would take some doing...
The pump should fit where the PAS pump goes, and I don't see a sane reason to worry about the difference in fluids causing problems. LHM vs Dex II is not the end of the world.
