  • 1 Vote(s) - 5 Average
dash clocks replacement help plz
Hi all my dash clocks, fuel gage and temp gauges have died on my 2001/02 1.9d berlingo van
Figured it's the actual clocks and not a censor or another fault so I'm after a new dash and just wondering if a set of clocks straight from a 1.4 2001 multispace would fit my van as i have sourced a cheap mail order one.
They look identical and look like they will fit but i'm just abit worried about connections and stuff at the back.
mileage is also lower on new set so would update auto right?
edit also it's petrol, mine is diesel does that make a difference.
would appreciate some help please thanks
did you check fuses for this,,, i wouldn't think replacing the clock will solve it,, something else wrong,,
(10-04-2014, 03:26 AM)joemc20 Wrote:  did you check fuses for this,,, i wouldn't think replacing the clock will solve it,, something else wrong,,
yeah checked fuses and bsi reset nothing. all the clocks don't work, speedo, rpm, temp and fuel. the LCD display light comes on but shows no mileage.
all the lights on dash work though like ecu and brake etc so the unit is powered just not working correctly.
Last Post: Beaumotor
Yesterday 04:38 PM
engine light
Yesterday 09:25 AM
M59 1.4 Petrol question
19-03-2025 06:12 PM
Cold Starting
Last Post: jboy012000
18-03-2025 10:46 AM
17-03-2025 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
Last Post: deejay_xb
16-03-2025 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
